Displays the log configuration for the specified target.
| console | Show the log configuration for the console display. |
| memory-buffer | Show the log configuration for volatile memory. |
| nvram | Show the log configuration for NVRAM. |
| primary-node | Specifies the primary node in a stack. |
| backup-node | Specifies the backup-node in a stack. |
| session | Show the log configuration for the current session (including console display). |
| syslog | Show the configuration for the specified syslog target. |
| ipaddress | Specifies the syslog IP address. |
| ipPort | Specifies the UDP port number for the syslog target. |
| tls_port | Specifies remote Syslog server Transport Layer Security (TLS) for connection type. |
| tls_port | TLS port number. |
| vr_name | Specifies the virtual router
                                that can reach the server IP address.  Note: User-created VRs are supported only on the platforms listed for
                                    this feature in the
    Switch Engine v33.1.1 Licensing Guide
     document..
| local0 ... local7 | Specifies the local syslog facility. |
If no options are specified, the command displays the configuration for the current session and console display.
If a virtual router is not specified, VR-Mgmt is used.
This command displays the log configuration for the specified target. The associated filter, severity, match expression, and format is displayed.
The following command displays the log configuration:
show log configuration target
The following is sample output from this command:
Log Target : memory-buffer Enabled ? : yes Filter Name : DefaultFilter Match regex : Any Severity : Debug-Data (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condit ion> Buffer size : 1000 messages Log Target : nvram Enabled ? : yes Filter Name : DefaultFilter Match regex : Any Severity : Warning (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condit ion> Log Target : console Enabled ? : no Filter Name : DefaultFilter Match regex : Any Severity : Info (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condit ion> Log Target : primary-msm Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Warning (through Critical) Log Target : backup-msm Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Warning (through Critical)
# sh log configuration
Debug-Mode: Disabled
    Enabled      : yes
    Match regex  : Any
    Format       : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition>
    Percent Full : 60%
    Full Alert   : None
Log Target       : nvram
    Enabled      : yes
    Match regex  : Any
    Enabled      : no
    Match regex  : Any
    Enabled      : yes
    Match regex  : Any
    Percent Full : 60%
    Full Alert   : 90%
Log Target       : nvram
    Enabled      : yes
    Match regex  : Any
    Enabled      : no
    Match regex  : Any
# show log configuration
    Enabled      : yes
    Match regex  : Any
    Percent Full : 100% (wrapping)
    Full Alert   : 90%
Log Target       : nvram
    Enabled      : yes
    Match regex  : Any
    Enabled      : no
    Match regex  : Any
Showing Syslog as log target:
# show log configuration target syslog
Log Target      : syslog; 10.68.6.3:6555 (vr VR-Mgmt), local0
    Enabled     : yes
    Match regex : Any
    Format      : PRI Mmm DD HH:MM:SS HOSTNAME TAG:
    Port Type   : TLS
    Recnct Cnt  : 2
    Recnct Msg  : CA Certificate not found. Use 'Download ssl certificate trusted-ca' command to download a CA certificate.
Log Target      : syslog; 10.68.6.3:6555 (vr VR-Mgmt), local1
    Enabled     : no
    Match regex : Any
    Port Type   : TLS
    Recnct Cnt  : 0
    Recnct Msg  : No Error
Log Target      : syslog; 10.68.6.3:6519 (vr VR-Mgmt), local0
    Enabled     : yes
    Match regex : Any
    Port Type   : UDP
The ipPort parameter was first available in ExtremeXOS 11.0.
The local0 ... local7 keywords were made optional in ExtremeXOS 11.4.
The udp-port parameter was added in ExtremeXOS 21.1.
Transport Layer Security (TLS) option added in ExtremeXOS 22.1.
Connection port type (TLS or UDP) and connection messages added in ExtremeXOS 22.1
